Need some help in C-code
Hello everybody
I need some help.
I have an MicroBlaze with some IO-Ports to communicate with VHDL-Components. MB is a component. MB should read some data (at *Baseadress_Data_in_ptr)
Here is my C-code:
TempStateOut = (TempStateOut | 0x00000001);
*Baseadress_State_out_ptr = TempStateOut; // ReadClk
do
while ((*Baseadress_State_in_ptr)& 0x00000040 != 0x00000040); //DataValid
TempStateOut = (TempStateOut & 0xFFFFFFFE);
// /ReadClk
 xil_printf(" "); // Important. But why????                      LINE XX
ucVar = (unsigned char)*Baseadress_Data_in_ptr;
If i add LINE XX the program is working properly. But if i comment that line i got some false Data. Can anybody tell me why?
Sincerely and wish u merry merry Chrismas
M.Rapp
Historian
Historian
Re: Need some help in C-code
m.rapp wrote:
Hello everybody
I need some help.
Here is my C-code:
do
// /ReadClk
M.Rapp
Perhaps when you put in the xil_printf(), you also add a delay that's long enough for  whatever data you're trying to read to become valid.
-a
I second that, and would also mention that maybe you're changing the state of the system by performing your operation.
In other words, the call to xil_printf() takes: (a) time, and (b) resources. So by using time you could be introducing a delay (as previously mentioned) that allows the expected result to occur. By using resources, you could be doing something where a value is 're-read' instead of used off the stack.
Let's look at the second one in more depth:
Let's say you have the following function:
int b = *(int*)(0xsome_address); int* c = (int*)(0xdifferent_address); *c = b; b = *(int*)(0xsome_address); /* address is the same as before */
In this example, B and C could have been allocated on the stack (or registers) and the compiler could assume that the address has not changed, therefore the state at that address hasn't changed and it won't re-read from memory for that value. Which is not what we expected. We wanted to write a value to C, then read the new state from B.
Now let's take a look at this example:
int b = *(int*)(0xsome_address); int* c = (int*)(0xdifferent_address); *c = b; do_func(); b = *(int*)(0xsome_address); /* address is the same as before */
Once again b and c should be allocated via registers or the stack. With the call to the function in there, now the compiler has to handle getting the value for b again. In this case, it could throw away the stack storage for b and just re-read it into a register after the call to do_func() finishes. This is what we expected to happen.
If you want to force the values to always be read, use the 'volatile' keyword in your declaration of a pointer:
volatile int *b;
This will force the compiler to always check the value at the address upon usage.
Professor
Professor
Another point.  The volatile declaration indicates that the object could change value due to some
process not visible to the compiler at the time of build.  So the declaration:
volatile int *b;
 tells the compiler to read the value pointed to by "b" each time you need to use it.
Now let's look at another case where the value of b (not *b but the pointer itself)
can change when the compiler doesn't know about it.  This could happen if
an interrupt routine updates a pointer to point to a new buffer location, for example.
Then you need to say that the pointer itself, and not just the data it points to,
is volatile like:
int * volatile b;
-- Gabor
Thanks for the answers
I tried to declare the pointer to volatile. But it did not work.
I dont know why.
It does not matter... I paste the line and OK.
Merry Christmas
M.Rapp
Professor
Professor
So you have two possibilities:
1)  The time that xil_printf takes makes a difference.  If this is the case you need to
make sure that the data is really available when your data valid bit is asserted.
2) The compiler has chosen to use an existing copy of the data rather than reading
it fresh.  This could happen if you have written recently to the data in question, or
if you have data cache in your system.  How does the data get to the area you
are reading?  Is it written by external hardware?  Is it updated in an interrupt routine?
Does the value of Baseadress_Data_in_ptr change during normal operation?  Can
you show us the declaration of Baseadress_Data_in_ptr?  If you only declared the
data pointed to by Baseadress_Data_in_ptr volatile, and not the pointer itself, you
may need to change the line:
to:
ucVar = (volatile unsigned char)*Baseadress_Data_in_ptr;
Gabor
-- Gabor
