Visitor mimmori
[Place Design Fail] Route PJTAG to FPGA IO through EMIO via Custom Logic
I am working on a project based on ZYNQ 7Z020.
I need to route PJTAG port from EMIO pins to FPGA pins not directly but through a multiplexer. I implemented the logic and all is ok except for TDO signal. I have a fail error during implementation phase.
Here the error: [DRC 23-20] Rule violation (REQP-1581) obuf_loaded - OBUFT Zynq_ps_inst/processing_system7_0/inst/PJTAG_OBUFT_TRUE.jtag_obuft_inst pin O drives one or more invalid loads. The loads are: Zynq_pl_inst/jtag_ctrl_inst/r_jtag_ctrl/SYS_conn_jtdo_OBUF_inst_i_1
It seems related to OBUFT present in the PS and that I can't pass through any logic. Is it true? If no, how can I realize this function?
Domenico
Tags (3)
Teacher muzaffer
Re: [Place Design Fail] Route PJTAG to FPGA IO through EMIO via Custom Logic
@mimmori you should have an output & a tri-state signal separately from PS and drive the actual tdo pin on PL with an assign which also controls the enable, ie:
output tdo;
wire tdo = tdo_tri ? 1'bz : tdo_out;
In other words you can't take the output of the OBUFT and drive it inside the FPGA. You need to take the inputs of the OBUFT (out & tri), take it through the PL and drive it at the PL IO as shown above.
@muzaffer I have the same problem. I found this table on the UG585:
So it seems that the PJTAG port have 5 signals, with the TDO split into the data and the 3-state control.
But, in the block design (Vivado 2016.6), when I enable the PJTAG, it comes with only 4 signals, and the TDO does not have the 3-state control signal.
So it seems that there is a software limitation in doing what you suggest,
Is there an alternative way to do it, or I'm doing it in the wrong way?
regards
Davide
Visitor mimmori
output tdo;
@muzaffer I can not take off from block design the input of the OBUFT. I don't konw how to do that.
Is there a way to bring out the TRI and the INPUT of the OBUFT instead of the output only?
Three years have passed since this post and no solution.  The problem remains.
How do we access the TDO_EN pin on the Zynq block?  On the Device View, I can see that the PS block has separate pins for TDO and EN, but there is no obvious way to get access to these during the block design phase.  Help please, Xilinx.
