Pmod signal output of constant voltaje that I would can modificate with terminal
Hi, well, I want to create a programa that use a microblaze and so use the terminal to create a output voltaje signal in Pmod (0- 1v signal that can be modified in real time by the terminal), I already can create a microblaze (and run the SDK interfaz), but I dont have idea that what type of Pmod add in the "ip block design"  in order to create the desire program, and too I dont know how to program the C code to generate the signal.
The target that I use is FPGA artyx 7 Basys 3.
Re: Pmod signal output of constant voltaje that I would can modificate with terminal
Hi @sitka,
In general users go for AXI GPIO for input output signals to PMOD connected externally.
But you need to add driver of PMOD manufacturer software driver supplied with device into SDK and then write application over it to test.
Praveen
