Visitor falchun
Problem to integrate the libraries of Xilinx to my project
Hello all!
I hope I post in the right topic.
I am in internship and I am trying to integrate the libraries of Xilinx in my project. My problem is when I try to simulate my project I have these warnings :
# ** Warning: (vsim-3473) Component instance "ppc405_adv_i : ppc405_adv" is not bound.
#    Time: 0 ps  Iteration: 0  Region: /testbench/d3/l3/cpu__0/u0/ppc405/ppc405_0/ppc405_0  File: /home/cao/xilinx/edk_8202i/hw/XilinxProcessorIPLib/pcores/ppc405_virtex4_v1_01_a/hdl/vhdl/ppc405_virtex4.vhd
I don't understand why it does that, because I didn't modify this file ...
And I have this error too :
# ** Error: (vsim-13) Recompile dcm_module_v1_00_a.dcm_module(struct) because dcm_module_v1_00_a.dcm_module has changed.
And I tried to compile dcm_module_v1_00_a.dcm_module(struct) (even I thinked it did not change anything) I have this error :
I don't know at all what I have to do :/ Somebody can help me please ?
Re: Problem to integrate the libraries of Xilinx to my project
The actual powerpc is represented as a "smartmodel" encrypted library.  You likely need to follow the directions in the documentation on how to set up smartmodels for simulation.
Also, it sounds like your modelsim libraries are out of date.  I'd suggest rerunning the xilinx library compilation with compedk, which will also help install the smartmodels.
Visitor falchun
I manage to correct my errors but not my warning.
For the personn who are interested, I had these errors because I did not combine my unisim_VCOMP.vhd, my unisim_VITAL.vhd and my unisim_VPKG.vhd correctly.
Visitor falchun
I always have my warning... I really don't understand. My entity ppc405_adv appears in the library work. Normally this entity should be in the library unisim... I tried many things to correct this problem, but now, I have no more idea to correct it. :(
edit : Sorry I forgot to say you : I use modelsim 6.5b and edk 8.2.02
Visitor falchun
Thank you for your answer.I reran the xilinx library compilation with compedk how you suggested me and it was that.
Thank you again ;)
