QSPI / STARTUPE3 constraints for VCU118
I need to add an AXI Quad SPI IP along with the STARTUPE3 primitive to my VCU118 design so it can access some data stored on the flash.
As a firs step I am trying to port the XAPP1280 from KCU105 to VCU118 board. To do that I need to add the appropriate timing constraints to account for the STARTUPE3 timing delays. The XAPP1280 design provides these values for the KCU105 board but I need the equivalent for VCU118. Is it possible for someone to provide the appropriate constraints for the the VCU118 board?
Alternatively if someone has a AXI Quad SPI reference design for VCU118, that would be great as well!
