SDK - dump printed data
Hi, I'm trying to make a project that prints AXI FIFO data on terminal and dump it to a text file. I'm using ZCU706 board.
So basically in the design there are PS - AXI FIFO IP blocks and some extras. I'm able to print out on the terminal window but I wonder how I can dump them into a txt file when there's hugh amount of text. Do I need to modify my SDK project, or it's out of SDK capability meaning should be done in the terminal?
Thank you.
Re: SDK - dump printed data
You can use the xsct 'mrd' command to read a block of memory to a file via jtag. And don't forget to use the '-size' option to overcome endianess.
