Observer cmuhlbauer
SPI Module in Zynq US+ Devices Register Reference, UG1087
In the description of Config (SPI) Register, field CS, I believe the following statement is incorrect:
"Peripheral chip select lines; valid only if [Manual_CS] = 1."
I think this field is valid when Manual_CS = 0 or 1, otherwise Auto CS mode doesn't know which CS to assert.
Also,  the CS field S/B defined differently when PERI_SEL=1, but this definition is not provided
Re: SPI Module in Zynq US+ Devices Register Reference, UG1087
Hi @cmuhlbauer,
Config(SPI)Register, statement about MANUAL_CS = 1 or 0 is correct.
MANUAL_CS = 1 then we have to manually select the chip select lines.
MANUAL_CS = 0 then SPI core will automatically select the chip select lines.
For your query regarding "CS field S/B defined differently when PERI_SEL=1, but this definition is not provided"
You have to set MANUAL_CS=1 to allow external 3 to 8 decoder as shown in snapshot below.UG1087.PNG
Thanks and Regards,
Deepak D N
Please Reply or Give Kudos or Mark it as an Accepted Solution
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Observer cmuhlbauer
I am concerned that by just doing the 3-8 decode of the Slave Select signals glitches may occur on the inactive slave select decodes.  Is this a problem I should be concerned about?
I wonder if Config (SPI) Register bit 13 is used to solve this problem since it doesn't have any other apparent use.
Scholar ericv
@cmuhlbauer
As specified, if the controller is not actively transferring data, there are no issues with CS glitches.
SPI operates on clock transitions and there are no clock transitions when inactive.
