Participant sarit8
Should optional signals of AXI4 be appear in the interface?
I write a testbench for a project which contain AXI4 bus.
Should optional signals of AXI4 be appear in the interface (which I connect to the dut)?
Community Manager
Community Manager
Re: Should optional signals of AXI4 be appear in the interface?
Defining or not defining the optional signals depends on your master and slave interfaces.
If your master or slave makes use of these optional signals and if they can impact the functionality then you should have a glue logic to connect drive these signals to an expected value.
What are the master and slave in your interface?
If both master's and slave's functionality is unaffected by these optional signals then you can leave them unconnected.
no optional signal not required
Thanks and Regards
Balkrishan
Participant sarit8
Why?
Community Manager
Community Manager
Participant sarit8
How can I mark the post as "Accept as solution"
