Time counter won't interrupt from load register
I'm new to uBlaze and have a noob question.  I'm just trying to get a simple timer to blink LEDs based on a timer interrupt.  The interrupt seems to work, but not based on the reset value I load into the load register.  It looks like it just interrupts when the register rolls over completely from all F's to 0's.  I believe this because I get the interrupt after 30 or 40 seconds which seems to make sense for a 32 bit register rolling over at 100Mhz.  Is there anything obvious I'm doing wrong?  Below is my code.
    * Configure UART for debug
    // Init uart
    XUartLite_Initialize(&debug_uart, XPAR_AXI_UARTLITE_0_DEVICE_ID);
    // Clear FIFOs
    XUartLite_ResetFifos(&debug_uart);
    // Self test
    if(XUartLite_SelfTest(&debug_uart) == XST_SUCCESS){
    	xil_printf("UART Configured!\n\r");
    // Enable Interrupts
    //XUartLite_EnableInterrupt(&debug_uart);
    // Assigne rx and tx handlers
    //XUartLite_SetRecvHandler(&debug_uart, (XUartLite_Handler)debug_uart_rx_isr, (void*)0);
    //XUartLite_SetSendHandler(&debug_uart, (XUartLite_Handler)debug_uart_tx_isr, (void*)0);
    Status = XTmrCtr_Initialize(&Timer0, XPAR_TMRCTR_0_DEVICE_ID);
    if(Status != XST_SUCCESS){
        	while(1);
    * Configure interrupt controller
    Status = XIntc_Initialize(&Interrupt_Controller, XPAR_MICROBLAZE_0_AXI_INTC_DEVICE_ID);
        	while(1);
    // Connect Timer interrupt to handler
    Status = XIntc_Connect(&Interrupt_Controller, XPAR_MICROBLAZE_0_AXI_INTC_AXI_TIMER_0_INTERRUPT_INTR, (XInterruptHandler)XTmrCtr_InterruptHandler, (void*)&Timer0);
     	while(1);
    // Enable Timer0 Interrupts
    XIntc_Enable(&Interrupt_Controller, XPAR_MICROBLAZE_0_AXI_INTC_AXI_TIMER_0_INTERRUPT_INTR);
    // Check for error
    //Status = XIntc_SelfTest(&Interrupt_Controller);
    //if(Status != XST_SUCCESS){
    // 	while(1);
    // Start controller
    XIntc_Start(&Interrupt_Controller, XIN_REAL_MODE);
********** * Configure Timer *********************************************************************************/ XTmrCtr_SetHandler(&Timer0, (XTmrCtr_Handler)MyTimerIsr, &Timer0); XTmrCtr_SetOptions(&Timer0, XPAR_TMRCTR_0_DEVICE_ID, XTC_INT_MODE_OPTION | XTC_AUTO_RELOAD_OPTION); XTmrCtr_SetResetValue(&Timer0, XPAR_TMRCTR_0_DEVICE_ID, 0x3FFFFF); XTmrCtr_Reset(&Timer0, XPAR_TMRCTR_0_DEVICE_ID); XTmrCtr_Stop(&Timer0, XPAR_TMRCTR_0_DEVICE_ID); /********************************************************************************* * Configure LED GPIO *********************************************************************************/ XGpio_Initialize(&LEDs, XPAR_LED_DEVICE_ID); XGpio_SetDataDirection(&LEDs, 1, 0x00); microblaze_enable_interrupts(); XTmrCtr_Start(&Timer0, XPAR_TMRCTR_0_DEVICE_ID);
I also noticed that when I have this block enabled:
    // Check for error
     	while(1);
I get a 1201 error returned that indicates that XIntc_SelfTest failed at this point below:
	 * Verify that there are no interrupts by reading the interrupt status
	CurrentISR = XIntc_In32(InstancePtr->BaseAddress + XIN_ISR_OFFSET);
	 * ISR should be zero after all interrupts are acknowledged
	if (CurrentISR != 0) {
		return XST_INTC_FAIL_SELFTEST;
Does anyone have any ideas?  I've been stuck on this simple problem of getting a basic timer to work for far too long.
Re: Time counter won't interrupt from load register
So I finally figured this out.  I am just posting up my solution for the community.  I configured my timer/interrupt controller as shown below.
        	while(1);
    	xil_printf("Fail!");
    Status = XIntc_Connect(&Interrupt_Controller, XPAR_MICROBLAZE_0_AXI_INTC_AXI_UARTLITE_0_INTERRUPT_INTR, (XInterruptHandler)XUartLite_InterruptHandler, (void*)&debug_uart);
    // Enable XUartLite Interrupts
    XIntc_Enable(&Interrupt_Controller, XPAR_MICROBLAZE_0_AXI_INTC_AXI_UARTLITE_0_INTERRUPT_INTR);
    // Check for error
    // Start controller
The configuration of the timer looks like this:
    // Init timer
    XTmrCtr_SetOptions(&Timer0, XPAR_TMRCTR_0_DEVICE_ID,	XTC_INT_MODE_OPTION | XTC_AUTO_RELOAD_OPTION | XTC_DOWN_COUNT_OPTION);
    XTmrCtr_SetResetValue(&Timer0, XPAR_TMRCTR_0_DEVICE_ID, 0xFFFFFF);
It looks like one big problem for me was that I was setting the load register to a number that I wanted the timer to stop at, but in up mode it doesn't seem to ever stop.  When I changed the timer to count in "down" mode it started working.  Who knew you couldn't use either.  I still don't know why my interrupt controller self check was failing, but it seems to be passing now that the timer is working.
I also added code to reset the timer by writing a 1 to the interrupt flag bit in the timer control register.  I guess you don't have to explicitly do this, but I keep it in just in case.  Below is the ISR:
void MyTimerIsr(void *CallBackRef, u8 TmrCtrNumber)
	XTmrCtr *InstancePtr = (XTmrCtr *)CallBackRef;
	uint32_t ControlStatusReg;
	LED_cnt++;
	//XGpio_DiscreteWrite(&LEDs, 1, (0xFF ^ XGpio_DiscreteRead(&LEDs, 1)));
	XGpio_DiscreteWrite(&LEDs, 1, LED_cnt);
	// Reset ISR Bit
	ControlStatusReg = XTmrCtr_ReadReg(InstancePtr->BaseAddress, 0, XTC_TCSR_OFFSET);
	XTmrCtr_WriteReg(InstancePtr->BaseAddress, 0, XTC_TCSR_OFFSET, ControlStatusReg | XTC_CSR_INT_OCCURED_MASK);
So I figured this out and wanted to reply with my solution.  When setting a count value as I was trying to do I had to set the counter to COUNTDOWN mode instead of count up mode.  After that things started working.
Hi @m3atwad
How to calculate the TIMER_LOAD_VALUE for specific time (like 1ms)?.
By private timer can i generate 1ms?
please suggest me regarding this .
Thanks and Best Regards
Vinod Sajjan
Your count value is just clock 1ms/clock period.  Just write this into your TIMER_LOAD_VALUE and set the timer to count down mode.  Your clock rate will be your axi clock if you are using the axi timer peripheral.
