Timer handler - save/restore INT context
In tmrcnt_X_X  documentation It says:
"Interrupts - It is the responsibility of the application to connect the interrupt handler of the timer/counter to the interrupt source. The interrupt handler function, XTmrCtr_InterruptHandler, is visible such that the user can connect it to the interrupt source. Note that this interrupt handler does not provide interrupt context save and restore processing, the user must perform this processing."
Where should user provide the save/restore of context  if it is not part of XTmrCtr_InterruptHandler responsibility ?
Is there any example of save/restore context in the BSP generated examples ?
Ran
Re: Timer handler - save/restore INT context
Has anyone solved this or found examples?  How can a BSP not provide the code to execute interrupts??
