Scholar beandigital
Timer interrupt only works once
I have a design that uses the Zynq timer to generate a 1 second interrupt. This works fine once. But if I disconnect the debug, change the code, then start the debug again, it doesnt work. Is there something else I need to add? Thanks
	Gic_Config = XScuGic_LookupConfig(XPAR_PS7_SCUGIC_0_DEVICE_ID);
	Status = XScuGic_CfgInitialize(&my_Gic, Gic_Config, Gic_Config->CpuBaseAddress);
	Timer_Config = XScuTimer_LookupConfig(XPAR_PS7_SCUTIMER_0_DEVICE_ID);
	Status = XScuTimer_CfgInitialize(&my_Timer, Timer_Config, Timer_Config->BaseAddr);
	Xil_ExceptionInit();
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_IRQ_INT, (Xil_ExceptionHandler)XScuGic_InterruptHandler, &my_Gic);
	Status = XScuGic_Connect(&my_Gic, XPAR_SCUTIMER_INTR, (Xil_ExceptionHandler)my_timer_interrupt_handler, (void *)&my_Timer);
	XScuGic_Enable(&my_Gic, XPAR_SCUTIMER_INTR);
	XScuTimer_EnableInterrupt(&my_Timer);
	Xil_ExceptionEnable();
	XScuTimer_LoadTimer(&my_Timer, XPAR_PS7_CORTEXA9_0_CPU_CLK_FREQ_HZ / 2);
	XScuTimer_EnableAutoReload(&my_Timer);
	XScuTimer_Start(&my_Timer);
Re: Timer interrupt only works once
If you restart the pl, without resetting the ps, then you may need to set the EOI during init. For example can you add the line in the interrupt init in your application Where XX is your interrupt ID
XScuGic_CPUWriteReg(&InterruptController, XSCUGIC_EOI_OFFSET, XX);
