Visitor hunly007
Transfer data from PL to PS using SPI, I2C or UART on Zynq
Anyone know? How can I transfer data from PL to PS using standart I/O like I2C, SPI or UART on Zynq. I am finding many tutorial but I did not found the example about hardware design in Vivado. I am using Microzed Board right now. Please give me some ideas about HW design.
Scholar austin
Re: Transfer data from PL to PS using SPI, I2C or UART on Zynq
h,
Why?
Transfers from/to PL and PS are best supported by the GPIO pins dedicated to that task, the HP AXI buses, the lowers speed GP AXI bus, or the cache coherent co-processor bus.
I suppose you may place a uart in the PL side, and connect it to a uart in the ps side using the EMIO pins internally,  or looping it out and back in again, but that seems inefficient to me.
Austin Lesea
Principal Engineer
Xilinx San Jose
Scholar austin
h,
Why?
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor hunly007
Thanks Moderator
But it is posible that I can transfer data from PL to PS by using EMIO such as SPI, I2C or UART? I am not sure about this. I have used AXI GPIO and I can send some of data from PL to PS. That data handled by Kernel Module and then send to Userspace. Now I would like to do the same way by using SPI, I2C or UART and I am not sure it is possible or not. I tried to find the example from any websites but I didn't get it. Could you tell me which IP Core that I can use to interface between PL to PS by using SPI, I2C or UART?
Scholar austin
h,
Yes, it is possible.
There are I2C, UART IP cores one may place in the PL just like an AXI core for the HP or GP buses.
Connecting it to the PS may be interesting, as I do not know how capable the EMIO programming is (do you need to use an external IO, or can you connect them internally?)..
Austin Lesea
Principal Engineer
Xilinx San Jose
Teacher muzaffer
EMIO is just wires into PL so they can equally terminate there instead of connecting to external IO pins. This makes it possible to convert the GMII interface to RGMII interface where PL logic modulates the EMIO signals to something which is significantly different in nature. I don't know why anyone would terminate I2C, UART etc in PL (virtualization?) but it's possible.
Visitor hunly007
Hi Moderator,
Yes I would like to connect them internally. And then I would like to generate some data from PL and send it to PS by using those standard I/O port. That mean I would like to send data from PL to PS by using I2C, SPI, or UART port but the data transfer just inside Zynq (PL to PS).
Hunly
Visitor hunly007
Please recommand me if anyone know the ways to design this in Vivado. Because I am a Newbie I do not know much about this. Please give me some example.
Visitor hunly007
Hi, This is my HW desgin. I am not sure it is work or not. I am using Microzed board and I stuck with constraint file.
Best regard,
Hunly
Visitor belalta4.
Hello, I am student i have to finish my project soon as soon possible  my project is    to send data from a sensor to a PC via UART in viva do and i use micro zed board 7010 . I have been using zynq processor  and  axi interconnect and axi UART lite . i generated bit stream and there is no error but i have some problem in sdk how can i initialize UART ..
 also after the communication i have to use just  micro blaze without processor  i mean the PL part do i write vhdl code
Thank you for your time
Hi @belalta4.,
Our Community Help has a tip that might help you : Tip: If the message is older than 6-12 months, please post a new message rather than adding to the existing thread. Your inquiry will have a better chance of being picked up by an expert if it is a new topic.
https://forums.xilinx.com/t5/help/faqpage/faq-category-id/posting#posting
I would suggest you create a new topic on the appropriate board
Florent
