Observer sberner66
Unable to run "hello world" on both r5 cores on ZCU104 with SDK 2018.3
Trying to run
int main()
    init_platform();
    print("Hello World from r5_0\n\r");
    cleanup_platform();
    return 0;
and
int main()
    init_platform();
sleep(1);
    print("Hello World from r5_1\n\r");
    cleanup_platform();
    return 0;
on both r5 cores via JTAG from SDK, but only get output from r0.
The same experiment works with multiple a53 cores although the output is inconsistent, means if I load "hello world" with different messages on a53_0 and a53_1 I get two times the message of a53_1 (??)
I am also unsuccessful running the second r5 core with remoteproc from linux. Can only run the first core.
What do I miss ?
Observer sberner66
Re: Unable to run "hello world" on both r5 cores on ZCU104 with SDK 2018.3
This was a silly problem, both cores were using the same memory.
Need to edit the linker script, can't simply create hello world for r5_0 and r5_1 and run them.
Observer sberner66
test
Observer sberner66
When running the two "hello world" programs on the debugger, r5_0 works normally while r5_1 fails in boot.S. At line 261, ldr r1, [r0], is jumps to the section below, at 0xffffxxxx. This doesn't make any sense because at line 261 there is no jump statement. Seems to me the binary is corrupted or the processor is malfunctioning. Tried on two different ZCU104 boards, same result.
257 isb
258 #if LOCKSTEP_MODE_DEBUG == 0
259 /* enable fault log for lock step */
000001e4: isb sy
260 ldr r0,=RPU_GLBL_CNTL
000001e8: ldr r0, [pc, #+204]
261 ldr r1, [r0]
000001ec: ldr r1, [r0]
262 ands r1, r1, #0x8
263 /* branch to initialization if split mode*/
000001f0: ands r1, r1, #8
264 bne init
265 /* check for boot mode if in lock step, branch to init if JTAG boot mode*/
000001f4: bne +64 ; addr=0x0000023c: init
266 ldr r0,=BOOT_MODE_USER
000001f8: ldr r0, [pc, #+192]
267 ldr r1, [r0]
ffff0010: cdple p14, 10, c11, c13, c15, 7
ffff0014: cdple p14, 10, c11, c13, c15, 7
ffff0018: cdple p14, 10, c11, c13, c15, 7
ffff001c: cdple p14, 10, c11, c13, c15, 7
ffff0020: cdple p14, 10, c11, c13, c15, 7
ffff0024: cdple p14, 10, c11, c13, c15, 7
ffff0028: cdple p14, 10, c11, c13, c15, 7
ffff002c: cdple p14, 10, c11, c13, c15, 7
ffff0030: cdple p14, 10, c11, c13, c15, 7
ffff0034: cdple p14, 10, c11, c13, c15, 7
ffff0038: cdple p14, 10, c11, c13, c15, 7
ffff003c: cdple p14, 10, c11, c13, c15, 7
ffff0040: cdple p14, 10, c11, c13, c15, 7
ffff0044: cdple p14, 10, c11, c13, c15, 7
Observer sberner66
257 isb
000001e4: isb sy
261 ldr r1, [r0]
264 bne init
267 ldr r1, [r0]
Observer sberner66
Can it be an interrupt ?
Interrupts are supposed to be disabled ?
Observer sberner66
The control and status register of r5_1, CPSR, indicates that the CPU is in abort mode after the incident,
Hex: 000001d7, Dec: 471, Oct: 0727
Bin: 0000,0000,0000,0000,0000,0001,1101,0111
Size: 4 bytes, readable, writable
The 5 LSBs indicate abort mode.
Observer sberner66
