Use of touch panel with the ZCU102 board
Hi all
I was wondering if someone has used a touch panel with  ZCU102 board preferably or any similar evaluation board.
I would like to control my application (data recorder) using a very basic User Interface (UI) that would run on a touch panel (7inch) connected to the PS side. The OS will be linux.
Has anybody came across with something similar or can suggest a type of touch panel that is available?
Thanx in advance.
Re: Use of touch panel with the ZCU102 board
Hi @amatsaka,
Please check http://picozed.org/product/ultrazed-io-carrier-card which has touch panel.
regards
Praveen
Hi @pvenugo
thanks for the suggestion. Indeed this board has the touch panel option (through the PL I guess) but the ZCU102 was selected for our project.
What I was thinking is an integrated touch panel that could be connected via the display port.
I have noticed a variety of drivers are already available through the petalinux kernel config under
Device Drivers ---> Input Device support --> Generic input layer --> Touchscreens
so there must be a way of using them.
Thanx
Newbie erezyosef
Did you get an answer ?
I also want to connect touch screen with ZCU102 board and I preferred connecting it through the PS.
Thanks, Erez
