Using FreeRTOS, PL-PS interrupt function called twice
We are using EMIO to generate a PL to PS interrupt on a Zynq with FreeRTOS. It works, but the interrupt routine is always called twice. Our code is mainly based on
https://forums.xilinx.com/t5/Embedded-Development-Tools/PL-PS-Interrupt-for-Zynq-running-FreeRTOS/td-p/487570
(see accepted solution)
Any idea why the interrupt is called twice?
By the way, is it better to use the IRQ_F2P signals? We did not find how to use them with FreeRTOS.
Vivado/SDK 2017.4, xc7z030ffg676-2
Re: Using FreeRTOS, PL-PS interrupt function called twice
Can anybody help?
Thank you
Sorry, I cannot help you.
I only wanted to post my experience relating to FreeRTOS and Zynq DMA.
I have a BD that implements DMA in both directions.
The DMA is being handled by a R5 on a ZCU102 eval board.
The R5 communicates the data coming from the fabric to a Linux process running
on the A53 via shared memory.
The Linux application and bare metal R5 code and FPGA perform excellent... never misses a beat.
I have been trying the last couple of days to move the R5 code from bare metal to FreeRTOS.
None of the DMA interrupts work correctly. I get one or more randomly, or none.
Most of my search finds suggestions like check that TLAST is getting generated correctly,
or you need to get the XScuGic instance from FreeRTOS via prvGetInterruptControllerInstance().
My TLAST is great and verified via R5 bare metal.
There is no such call prvGetInterruptControllerInstance();
I can see the FreeRTOS getting a XScuGic and looking it up to set tick interrupt,
but no API to get at it. There just seems to be a lot of misinformation and lack
of a comprehensive enough example to demonstrate the technology.
Disappointing indeed!
Is the behavior apecific to using FreeRTOS? Have you tried using a similar bare metal application to test the interrupt response?
Also, have you veriied using an ILA that the interrupt is only active once and deasserted properly once cleared?
Christophe
Re: " Have you tried using a similar bare metal application to test the interrupt response?"
Perhaps you missed this part of my post...
Re: "Also, have you veriied using an ILA that the interrupt is only active once and deasserted properly once cleared?"
No, why would I do that? Why would the interrupt only be "active once".
Precisely how would I clear an interrupt that I am never getting please?
DMA works great in the bare metal application, but not in Xilinx
supported Free RTOS.
