Vivado SDK Error: Description Resource Path Location Type fatal error: WProgram.h: No such file or directory PmodTMP3.h /temp_app/src line 23 C/C++ Problem
hii..
Im doing PMOD temparature (Pmod tmp-3) sensor with zedboard using vivado 17.1 and SDK.
while loading C code in application  it is showing the message like above:
I have attached the code, pls suggest me solution
Re: Vivado SDK Error: Description Resource Path Location Type fatal error: WProgram.h: No such file or directory PmodTMP3.h /temp_app/src line 23 C/C++ Problem
Hi @nagendra_coreel,
This seems to be Audrino based header file and is not added to SDK workspace.
Could you please check is custom driver files are properly generated in BSP?
Praveen
