Where should I put the constraints when instantiating an XPS design in ISE 12.3?
When instantiating an XPS project in ISE (with a VHDL wrapper that uses the same names for IO-ports), how should I handle the constraints files? If I copy the UCF from my XPS project and add to my ISE project I get a lot of warnings about constraints being overridden. Then, if I try to remove my top-level UCF file some of my IO end up being UNLOCATED.
Re: Where should I put the constraints when instantiating an XPS design in ISE 12.3?
If your EDK project is a sub-module in ISE, ie.
my_top.vhd/.v
  --xps_sub.xmp
  --other logic (vhd or v)
you should not be worried about your XPS constraint file in /data directory in XPS project directory. This file will be picked up automatically when you run the implementation in ISE.
"Don't forget to reply, kudo and accept as solution."
my_top.vhd/.v
  --xps_sub.xmp
Thank you for the answer and sorry for the late reply.
I removed the UCF from my ISE project, cleaned and rebuilt netlist in XPS, then ran implementation from ISE.
I still have a problem with an IO constraint not being applied.
In /system/data/system.ucf I have these two lines
NET xib_ipci_0_pagesel_pin<0>           LOC = AC33 |  IOSTANDARD = LVCMOS33;
NET xib_ipci_0_pagesel_pin<1>           LOC = AB33 |  IOSTANDARD = LVCMOS33;
They are copied (by ISE/Project navigator ?) to a system.ncf file in my ISE project dir.
However, I get these warnings when I run the implementation from ISE:
Place:837 - Partially locked IO Bus is found.
 Following components of the bus are not locked:
     Comp: xib_ipci_0_pagesel_pin<0>
Place:838 - An IO Bus with more than one IO standard is found.
Components associated with this bus are as follows:
     Comp: xib_ipci_0_pagesel_pin<0>   IOSTANDARD = LVCMOS25
     Comp: xib_ipci_0_pagesel_pin<1>   IOSTANDARD = LVCMOS33
For some reason the location and IO-standard contraint for pagesel_pin<0> is not applied.
Any ideas?
I found a solution/workaround:
I moved the location & IO standard constraints to a new UCF-file (leaving the rest in system/data/system.ucf) and added it to my ISE project and now my IOs gets constrained correctly.
