XADC XsysMon_CfgInitialize
I am trying to use XADC in my application. I designed the hardware and exported it to SDK. I build the code successfully but while running the code it stucks at XSysMon_CfgInitialize function. On debugging, I found the application calls DataAbortInterrupt. I am using Zybo board and 2016.4 Vivado and SDK version. I found this question on the following link too but unfortunately it is unanswered.
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=EMBEDDED&message.id=17253
Please find attached my hardware design, address editor tab and code
Thanks & Regards
Vishav
Re: XADC XsysMon_CfgInitialize
I figured it out. I did not enable AXI4Stream in the hardware design. I thought it would be enabled by default by Vivado. Here is the screenshot.
Vishav
I've never used the Zybo board.
I have used other HW and had no issues with the CfgInitialize in this case.
Are you sure that there is no problem with the XADC? is it running as expected.
If is out of reset and are you seeing EOC/EOS coming out of it.
Vishav
