Visitor epech
XCanPs Self Test Fails
The Hardware
  • I'm using a Microzed + Embedded Vision Carrier Card
  • I enabled the CAN0 interface and mapped it to MIO 10-11 (see image below)
The Software
I regenerated the BSP and I'm now able to see the XCanPs driver in the BSP.
I initialize the controller:
	pCanPs_config = XCanPs_LookupConfig(XPAR_PS7_CAN_0_DEVICE_ID);
	XCanPs_CfgInitialize(pdemo->pCan, pCanPs_config, 0xAA);
Then I call the self-test function
XCanPs_SelfTest(pdemo->pCan);
The Problem
Self test fails because the mode is not Config (see image below where it fails), the mode is XCANPS_MODE_SLEEP:
Tags (4)
Visitor epech
Re: XCanPs Self Test Fails
It's working now. There were 2 problems:
  • The following line of code was incorrect, the second parameter shouldn't be 0xAA
  • 	XCanPs_CfgInitialize(pdemo->pCan, pCanPs_config, 0xAA);
  • For whatever reason SDK was downloading an incorrect Bitstream.
Visitor epech
