Observer parijatbajpai
Xapp1026 memory file system help
hi
i m using EDK12.1 and running the applications of XAPP1026.
for creating  new mfs file i m using following command
mfsgen -cvbfs new_image.mfs <num_block> <file list>
for downloading this file i am using the command
dow -data new_image.mfs <load_address>
1 .how to decide  <num_block> parameter?
2. how to decide <load_address> parameter?
Re: Xapp1026 memory file system help
For 2, the <load_address> is the starting address of the memory you would like to store your image. Normally, the size of the memory from the <load_address> to <end_address_of the memory> should be big enough for the image file you created.
"Don't forget to reply, kudo and accept as solution."
