Visitor nik_dan
Xapp1320 not working on zcu102 board
I have followed given in xapp1320,
Vivado 2017.3 is being used, with zcu102 board. on windows-10
following are the snapshot for settings:
After making the bit file and transferring it to SDK, first there was an error while making R5_FSBL, it asked to add I2C_0, which I added, as you can make out in attached configurations image. Also, GEM-3 was removed, as otherwise there was MIO clash.
After boot.bit file was generated as instructed in xapp1320,  It was then, transferred to SD card and put in ZCU102 (SW-8 =. 1110).... the following was displayed on terminal and done LED went RED.
Xilinx Zynq MP First Stage Boot Loader
Release 2017.3   Feb  5 2018  -  16:20:17
Reset Mode      :       System Reset
Platform: Silicon (4.0), Cluster ID 0xC0000100
Running on R5-0 Processor, Device Name: XCZU9EG
Initializing TCM ECC
Address 0xFFFD64A0, Length FFE00020, ECC initialized
Address 0xFFFD64A0, Length FFE20000, ECC initialized
Board Configuration successful
Processor Initialization Done
================= In Stage 2 ============
SD1 with level shifter Boot Mode
SD: rc= 0
File name is 1:/BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x4
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x65216F
Data word offset: 0x65216F
Total Data word length: 0x65216F
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0x5220
Partition Attributes: 0x26
Destination Device is PL, changing LoadAddress
Please let me know, which configuration went wrong?
Please note, if following info is also helpful: while following UG-1209
1. The PS memory test does not pass during BIST.
2. With Isolation configuration, it wasn't possible to run "hello world" on R5_0, though it worked while following it for vivado 2017.2 i.e without isolation
Thank you.
Scholar austin
Re: Xapp1320 not working on zcu102 board
Note:  Xapp1320 is written for 2017.1,
No other versions are supported.  Please note what versions apply to what documents.
Austin Lesea
Principal Engineer
Xilinx San Jose
Visitor nik_dan
Dear,
Sorry for the delayed response.
how should I perform the same task on 2017.3 then?
Please, tell the changes to be made for the same.
I would like to run through XAPP1320 but I also have Vivado 2017.3. Would you recommended loading on the old software to enable the XAPP to work?
I don't really want to go back but I would be happy to go forward to the latest Vivado, if you know of any similar isolation  tutorial/examples that work.
Hi Nik_dan,
for the fsbl bitstream loading issue try setting XFSBL_PL_PWRUP_WAIT_MICROSEC to 10 in xfsbl_bs.h.
Alternatively check if timers are enabled (TTC) and accessible from R5.
There were some significant issues with the application note especially for software versions prior to 2018.1.  I just released a major update that should  address your issues.  However, it targets Vivado 2018 (tested on 2018.1 - 2018.3).
