Observer abc123wyj
ZC706 PS Ethernet to sfp
hello all,
    I have a ZC706 board with a Zynq 7045 that I am developing on. I want to test ps emio sfp ethernet funtion.
    I found XAPP1082 in the xilinx website and download reference design files.
    I copy boot.bin and image.ub files which are contained in read_to_test/ps_emio_eth_1000base-x folder into SD card.
    Then I switch to SD Mode and short the J17 with jumper to enable SFP.
     When I power up the board, linux can work, but PHY is not detected, and ethernet can not link with PC.
     Where am I wrong? Would anyone help me?
     The serial ports prints as follows:
inside ProgramSi5324
clock programming Success!
U-Boot 2017.01 (Feb 09 2018 - 11:34:54 +0530)
Board: Xilinx Zynq
I2C: ready
DRAM: ECC disabled 1 GiB
MMC: sdhci@e0100000: 0 (SD)
SF: Detected s25fl128s_64k with page size 512 Bytes, erase size 128 KiB, total 32 MiB
In: serial
Out: serial
Err: serial
Net: ZYNQ GEM: e000b000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@e000b000ZYNQ GEM: e000c000, phyaddr 1, interface rgmii-id
PHY is not detected
GEM PHY init failed
U-BOOT for ps_emio_eth_1g
ethernet@e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
mdio_register: non unique device name 'eth1'
Device: sdhci@e0100000
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.2 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
10652140 bytes read in 970 ms (10.5 MiB/s)
Using 'conf@1' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000d4
Data Size: 3747616 Bytes = 3.6 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: 197ae0f0fed690d689d069ec63cabc08712f651a
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Data Start: 0x10396984
Data Size: 6888567 Bytes = 6.6 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 51b4641203df5090ca13bf9f64e761a19bbf89bd
Trying 'fdt@0' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x103930e8
Data Size: 14314 Bytes = 14 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 71fba83a9def0486af3d1c36d735f3194ab41566
Booting using the fdt blob at 0x103930e8
Loading Kernel Image ... OK
Loading Ramdisk to 0796e000, end 07fffc77 ... OK
Loading Device Tree to 07967000, end 0796d7e9 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 4.9.0-xilinx-v2017.4 (sutejk@xhdnaveenku40) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Fri Feb 9 11:33:37 IST 2018
OF: fdt:Machine model: xlnx,zynq-7000
bootconsole [earlycon0] enabled
cma: Reserved 16 MiB at 0x3f000000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @ef7d2000 s25932 r8192 d23220 u57344
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260608
Kernel command line: console=ttyPS0,115200 earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1006136K/1048576K available (6144K kernel code, 200K rwdata, 1460K rodata, 1024K init, 229K bss, 26056K reserved, 16384K cma-reserved, 245760K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0700000 (7136 kB)
.init : 0xc0900000 - 0xc0a00000 (1024 kB)
.data : 0xc0a00000 - 0xc0a320c0 ( 201 kB)
.bss : 0xc0a320c0 - 0xc0a6b758 ( 230 kB)
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to f0802000
slcr mapped to f0804000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080c000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x100000 - 0x100058
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 26, base_baud = 3125000) is a xuartps
`k奖晛[ttyPS0] enabled
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Freeing initrd memory: 6728K (c796e000 - c8000000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=30 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f086d000
[drm] Initialized
brd: module loaded
loop: module loaded
m25p80 spi0.0: found s25fl128s, expected n25q512a
m25p80 spi0.0: s25fl128s (32768 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000002000000 : "spare"
libphy: Fixed MDIO Bus: probed
CAN device driver interface
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 28 (00:0a:35:00:1e:53)
Marvell 88E1116R e000b000.etherne:07: attached PHY driver [Marvell 88E1116R] (mii_bus:phy_addr=e000b000.etherne:07, irq=-1)
macb e000c000.ethernet eth1: Cadence GEM rev 0x00020118 at 0xe000c000 irq 29 (00:0a:35:00:00:01)
Xilinx PCS/PMA PHY e000c000.etherne:01: attached PHY driver [Xilinx PCS/PMA PHY] (mii_bus:phy_addr=e000c000.etherne:01, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 23
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at f098b000 with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 1024K (c0900000 - c0a00000)
mmc0: new high speed SDHC card at address 17f8
INIT: mmcblk0: mmc0:17f8 SE08G 7.22 GiB
mmcblk0: p1 p2
version 2.88 booting
Starting udev
udevd[718]: starting version 3.2
random: udevd: uninitialized urandom read (16 bytes read)
udevd[719]: starting eudev-3.2
random: fast init done
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Populating dev cache
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue Mar 20 15:09:45 UTC 2018
Starting internet superserver: inetd.
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.24.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDNOlMU3WZpC/5LbsDeGrfPL8m6WJLFWrevUymt4TWlkxNBoQWQ6104vVVazDDlCchDpSE6qAseCC0Igb4q+h8fxkH77QG1i8rTmJoffCLfZOy19RTOigg4sAffGcV9jqKHWNqtTTPX7XDYsAfOv0nfG+UELPbolQ8NnhMMqtEQN29bAOJngfmC4hVUNSkxnO0/7061xDgmUYF0DrtTWQHYcUfTpcrvjQeSA2u3rhmZU0W8jsEzVdwlPLonTHj5ck3Bhv2j9w411H6xjA7b5R205Io3H+s77DlmMyR5zdySMatEhR9N957FT53M0GWVTtzXXgVD9MQIQQWhXeKTuh0F root@ps_emio_eth_1g
Fingerprint: md5 3f:1f:f7:ce:94:3f:c9:71:33:cc:bc:0d:d9:43:02:db
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2017.4 ps_emio_eth_1g /dev/ttyPS0
ps_emio_eth_1g login:
my board as follows:
Re: ZC706 PS Ethernet to sfp
Hi @abc123wyj,
Make sure you are using correct SFP cage adapter  and RJ45 cables- for 1G 1000BASE-X validation, Cisco GLC-T 1000BASE-X Ethernet to SFP Module is used(SN : AGM170623ZT).For 1G SGMII validation, Cisco GLC-T 1000BASE-T 100m RJ45 Ethernet to SFP Module is used(SN : CLS10310606) to be used.
FYI,  is the wiki page http://www.wiki.xilinx.com/Zynq+PL+Ethernet for XAPP1082.
Praveen
Observer abc123wyj
Hi pvenugo
