Visitor rtapiador
ZCU-102 GPIO ACCESS WITH PETALINUX
We want to access to an AXI-GPIO module in a Ultrasale plus(ZCU102) plattform using a Petalinux OS. Following the tutorial in the Xilinx wiki, we tried the following command:
echo 511 > /sys/class/gpio/export
There were not any problem with the command above. However when we tried to run the next command the system gets completely stuck and we have to reboot the board manually.
echo out > /sys/class/gpio/gpio511/direction
We have seen that in recent versions of Petalinux there were some changes in GPIO access with spinlock protection.
2018.2
Summary:
  • gpio: zynq: protect direction in/out with a spinlock
We want to know, how to access to a GPIO from the user space.
Kind Regards
Kind Regards.
Re: ZCU-102 GPIO ACCESS WITH PETALINUX
gpio511 doesn’t seem correct. I would expect gpio504 perhaps?
Anyway, Can you do a ls /sys/class/gpio? You should see
export gpiochip330 gpiochip5xx unexport
Where gpiochip5xx would be your axi gpio controller. However, to see what controller this corresponds to, you can read the label. For example
cat /sys/class/gpio/gpiochip504
to see the amount of pins on this controller
cat /dts/class/gpio/gpiochip504/ngpio
then to toggle a pin
echo 504 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio504/direction
echo 1 > /sys/class/gpio/gpio504/value
Visitor rtapiador
I checked everything and it is listed, the gpio 511, the value of GPIO is correct(1), However when i tried to do the echo out command all the system hangs.
I dont know what more i can do.
