ZYNQ Boot Devices (QSPI+emmc)
Can I boot the LINUX system with QSPI and EMMC?  In some fileds, the SD-CARD is forbidden。I must use the EMMC instead of SD-CARD.
Re: ZYNQ Boot Devices (QSPI+emmc)
THANK YOU VERY MUCH!!
Scholar ronnywebers
yes it's possible. Zynq can however not boot directly from eMMC, so you need to boot FSBL + U-Boot from QSPI and from there you can load the rest of the image from eMMC.
There's some blog post about this : https://www.beyond-circuits.com/wordpress/tutorial/tutorial27/
The blog refers to a document from Avnet, but the link is broken. I found the document using google, somewhere on the xilinx forum :
Booting PicoZed using QSPI and eMMC - Xilinx Forumshttps://forums.xilinx.com/xlnx/.../PicoZed_Petalinux_2014_4_eMMC_boot_v2.0.pdf
fyi : Zynq US+ can even directly boot from eMMC
Look at AR66846, that might help you out.
Scholar ronnywebers
@wandtdk  please set the post that answered your question as accepted solution, that will help other users find the answer more quickly...
