Zc706 board Clock Pins
I am trying to blink my zc706 board but I dont know which clock pins to use also I cant find io standart lvds or lvds_25 on my Vivado 2015.4 I/O Port list .I read some other question but I didnt get the idea of diff clock I just simply blink leds of my zc706 board thank you
Re: Zc706 board Clock Pins
You can use any clock if all you're trying to do is to get a quick LED blinking design going. I would just use the 200MHz 2.5 LVDS system clock. Pin/port locations are given in the user guide UG954.
You're not seeing LVDS in the IO port list because you haven't' connected the input FPGA clock capable pins to a differential IO buffer. Just connect your input to an IBUFDS for example. Use the IBUFDS output to source your design load.
@nisanurbakir Did you go through UG954 http://www.xilinx.com/support/documentation/boards_and_kits/zc706/ug954-zc706-eval-board-xc7z045-ap-soc.pdf
Check Appendix C that will list the constraints of the system clock and what IO standards to use for LED's.
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
I checked this list but I dont know which clock to use to control leds also lvds or lvds_25 io standards not on the vivado io port list
