12-12-2017 08:10 AM
Dear all,
I would like to use Zedboard Evaluation Board 7z020 in order to send lots of bytes over Gigabit Ethernet (bare metal system).
The PS should receive bytes from PL through AXI DMA Rx interrupt and then it should transfer them over GbE.
DMA SG Stream to MM occurs every 20ms and transfer 32Byte of data to PS.
My firts attempt, which was working well, was the following
I have then modified lwip configuration in order to maximize throughput, following the configuration described in last two pictures of the following link:
Now I can transfer a big packet of 65KB, but DMA doesn’t work anymore.
I read the following errors:
Dump registers 40400030:
Control REG: 00017002
Status REG: 00010109
Cur BD REG: 00FB78C0
Tail BD REG: 0110FFC0
The following pictures shows memory status after DMA initialization. When first interrupt occurs, no data is copied at register 0x00FC19C0.
Where is the problem? Can yuo help me?
Thanks very much
Best regards
Sara
12-14-2017 07:35 AM
I resolved my problem closing Vivado and SDK software, and lunching them again .
Bye
12-14-2017 07:35 AM
Bye
03-20-2018 12:43 PM
Can you share your code for the DMA to UDP packet that you got to work properly?
01-28-2019 03:28 PM
Can you please share your code with us? Thank you.
