Zybo + Microblaze + uart
Hello
I'm using vivado 2014.2 and I am trying to interface UART IP for bluetooth Pmod with Microblaze IP on ZYBO Z-7010 AP. Can you tell me how to configure the clock in constraint file?
Thank You
Re: Zybo + Microblaze + uart
Hi chinmay@30,
Clock constraint may look like the example
-> create_clock -period 10.000 -name sys_clk_100mhz -waveform {0.000 5.000} [get_ports clk_System100MHz_p]
Praveen
HI,
What issue you are facing? Explain it...
Madhu
