To launch batch mode, run the command below in an SDK shell:
xsdk -batch
To create a Hardware Platform:
create_project -type hw -name hw_0 -hwspec system.hdf
To create a Base System Platform (BSP):
create_project -type bsp -name bsp_0 -hwproject hw_0 -proc microblaze_0 -os standalone
Where, OS can be standalone, or xilkernel
To create an Application:
create_project -type app -name helloworld -hwproject hw_0 -proc microblaze_0 -os standalone -lang C -app {Hello World} -bsp bsp_0
Below are the available template applications:
Standalone/Baremetal and Xilkernel OS Application Templates for Language C:
{Hello World}
{Empty Application}
{Peripheral Tests}
{Memory Tests}
{Zynq FSBL}
{Zynq DRAM tests}
{Dhrystone}
{lwIP Echo Server}
{RSA Authentication App}
{SREC Bootloader}
{Xilkernel POSIX Threads Demo}
Standalone/Bare metal and Xilkernel OS Application Templates for Language C++:
{Empty Application}
Linux OS Application Templates for Language C:
{Linux Hello World}
{Linux Empty Application}
{OpenCV Example Application}
Linux OS Application Templates for Language C++:
Below is an example for a Typical MicroBlaze design exported from Vivado.
This creates a Hardware Platform, BSP, and a Hello World Application:
xsdk -batch -source test.tcl
#Example test.tcl
#!/usr/bin/tclsh
set_workspace workspace
create_project -type hw -name hw_0 -hwspec <path the HDF file>.hdf
build -type bsp -name bsp_0
build -type app -name helloworld
clean -type all
build -type all
exit
Below is an example for a typical design exported from Vivado.
This uses the HSI to find the processor, creates a Hardware Platform, BSP and a Custom Application and copies the sources files and builds:
#Example test.tcl
#!/usr/bin/tclsh
open_hw_design workspace/hw_0/system.hdf
set proc [::hsm::utils::get_procs]
set proc [lindex $proc 0]
if {$proc != ""} {
create_project -type bsp -name bsp_0 -hwproject hw_0 -proc $proc -os standalone
} else {
puts "No Processor found in design"
exit
create_project -type app -name myapp -hwproject hw_0 -proc $proc -os standalone -lang C -app {Empty Application} -bsp bsp_0
file copy -force <path to source file> workspace/myapp/src
build -type app -name myapp
clean -type all
build -type all
exit
Below is an example for a typical Zynq design exported from Vivado.
This creates a Hardware Platform, BSP, and an FSBL application:
#Example test.tcl
#!/usr/bin/tclsh
create_project -type hw -name hw -hwspec <path the HDF file>.hdf
cd workspace/hw
open_hw_design system.hdf
set bsp [create_sw_design bsp -proc ps7_cortexa9_0 -os standalone]
add_library xilffs
generate_bsp -sw $bsp -dir ../bsp -compile
cd ../..
create_project -type app -name fsbl -hwproject hw -proc ps7_cortexa9_0 -os standalone -lang C -app {Zynq FSBL} -bsp $bsp
build -type bsp -name $bsp
build -type app -name fsbl
clean -type all
build -type all
Thanks and Regards
Balkrishan
