Zynq MPSoC BootROM Error Code Definitions
I am looking fordescriptions of the BootROM error codes for the Zynq MPSoC. By BootROM error code, I am referring to the ERROR_TYPE field in the CSU_BR_ERROR register. I cannot find the descriptions in the TRM (UG1085) or anywhere else in the Zynq MPSoC documentation.
For the Zynq-7000, these codes are described in the TRM (UG585) in Table 6-20, but there is no such table in the Zynq MPSoC TRM.
Re: Zynq MPSoC BootROM Error Code Definitions
Missed error codes will be documented in next versions.
Please find the attached boot rom error codes.
Kranthi
Best Regards
Kranthi
Kranthi
Best Regards
Kranthi
