Zynq MPSoC EV device.. Question on VCU Power Supply..
I am doing a custom designed board with a 7EV device on it, and I have a question about the VCU power supply.  In our production system, we are not going to use the VCU right away, but in the future we will use it.
My question is, can I turn the VCU supply off, with all the other power rails up and running if I am not using the VCU, without any issues with the rest of the Zynq chip?   Do I need to ground the VCU power supply rail if I am not using it?   I can add the option to Ground the Power rail on the board design.
Thanks for the help.
jechambe
Re: Zynq MPSoC EV device.. Question on VCU Power Supply..
Hi @jechambe-koe ,
We do not have such. YOu can try gating the clock &
requesting pmu to disable the VCU node[every HW IP block in mpsoc is a node in terms of power] from Linux/baremetal.
YOu can refer below wiki to understand the power management and requesting/releasing a node from PMU.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842232/Zynq+UltraScale+MPSoC+Power+Management+-+Linux+Kernel
UG1137 for VCU NODE. I see VCU node is 63.
Best Regards
Kranthi
