Visitor nitron
Zynq7020 Critical Section code
On a Zynq 7020 (Cortex A9) I have some critical section code.
By critical section I mean a section of code that should not be interrupted by any ISR.
So  before entering the critical section code I disable all the interrupts and after the critical code is executed I enable them afterwards like this:
Xil_ExceptionDisable()
// execute critical code, 5-10 lines of basic code so very short in time
Xil_ExceptionEnable()
The problem is that sometimes some interrupts are missed so I wonder:
1. If an interrupt is triggered during the critical code execution then the interrupt is it serviced just after Xil_ExceptionEnable() (the desired behavior) or it disapears forever in the darkness ?
2. What is the standard way of entering and leaving a critical section code ? Can anyone share a code example?
Thank You for your answers!
Scholar ericv
Re: Zynq7020 Critical Section code
@nitron
the procedure you are using is perfectly OK as a mechanism to protect a shared variable in your application. And yes, what @xilinxacct refers to is better because interrupts are not disabled.  When interrupts are disabled / enabled on the A9 through the CPSR register (this is what Xil_ExceptionDisable / Xil_ExceptionEnable do) then when an interrupt occurs during the disabling it remains pending until the interrupts are enabled and it then get procesed.
Is it possible your CPU interrupt takes some times more time to perform the processing than the rate of the interrupts?
If so, there could be a latency build-up so once in a while an interrupt would be missed..
Teacher xilinxacct
@nitron
When you say 'critical section' are you trying to protect a shared variable OR maintain some explicit instruction completion time? Of course, if neither, interrupts are saving and restoring their state, so 'maybe' you don't need it (depending on what you mean).
Knowing what 'you' mean by 'critical section', may help a more specific answer.
Visitor nitron
Thank you for your answer.
By critical section code I mean a code section where I want to protect the access to a shared variable.
One more detail: I have a bare metal application with only one computation intensive interrupt and a backgound task (infinite loop, low priority). The interrupt occurs at very regular intervals. I see spurious interrupts missing (maybe one in a million or even less often).
I have some status register that can be modified both by an interrupt and the infinite loop routines (background, low priority tasks).
When I modify this status register in a low priority task (infinite loop) before altering the content of the register, I disable the interrupts in order to avoid any possible content corruption of the register from an interrupt popping up just in the middle of the low priority task processing.
I know there are other ways of protecting a variable access than disabling all the interrupts during access.
My real concern is that I see missing interrupts so I am not sure that the procedure I am using to disable interrupts are the correct one or I am missing something that leads to interrupt loss.
I must say that the interrupts remain disabled for a very short time (4-5 simple lines of code like setting/resetting bits in different status registers). So the non-interruptible code section cannot take too long in order to hinder the interrupt occurrence.
The processor load is about 30% so the interrupt loss is not caused neither by an processing overload.
At this stage my only clue is that maybe I am doing something wrong with the interrupt disabling procedure and if an interrupt event occurs during the very short window when the interrupts are disabled then the interrupt is not serviced after the interrupts are enabled (the interrupt is lost).
That's why I am asking if my way of disabling and enabling interrupts is OK.
Best Regards,
Teacher xilinxacct
@nitron
If your interrupt & background task in on the ARM, take a look here, and see if it helps ... https://stackoverflow.com/questions/51795537/critical-sections-in-arm
Use atomics if you can.
If in PL, look at the Mutex IP, and see if you can utilize that.
Hope that helps
If so, please mark as 'solution accepted'
Scholar ericv
@nitron
Visitor nitron
Thank you guys for your answers!
@ericvYour answer confirms that the way I disable and enable interrupts cannot be the cause of interrupts missing. I'll wait some time in order to potentially have other (potentially divergent) opinions and if not I'll mark your answer as accepted solution.
Regarding your question: Is it possible your CPU interrupt takes some times more time to perform the processing than the rate of the interrupts?
The interrupt occurs every 50us. I see that once in a while one interrupt is missing since I monitor the time elapsed between two consecutive interrupt entry points. This time doubles when one interrupt is missing.
From what I know (I measured) the maximum time the interrupts takes is about 19us (regularly 15us). So it seems this is not a problem of processor overload. As I said i have only one interrupt in the system in order to increase determinism so it is only this interrupt that determines the processor load.
I'll look further to other possible (unknown) causes.
@xilinxacctThank you for your answer. I was aware about the stackoverflow thread but not about Mutex IP in PL. I'll give them a look after hopefully the problem with losing interrupts is solved.
