Visitor heitbrsp
bare metal axi iic interrupt help
I'm trying to get an i2c AXI peripheral to work on a Zynq board. I have the thing working in so far as it actually is able to send messages, but I seem to have problems getting the interrupt system to work. In this system the iic IP interrupt is hooked directly into the interrupt port of the zynq processor. I found the example bare metal i2c in the BSP program along with the scu/gci BSP example. I've combined the two together, but I'm still not seeing any interrupts.  I've posted the program below. Any hints would be helpful.
/************************** Constant Definitions *****************************/
 * The following constants map to the XPAR parameters created in the
 * xparameters.h file. They are defined here such that a user can easily
 * change all the needed parameters in one place.
 * The following constant defines the address of the IIC
 * temperature sensor device on the IIC bus. Note that since
 * the address is only 7 bits, this  constant is the address divided by 2.
#define CAMERA_SLAVE_ADDRESS	0X30	/* camera read addr */
/**************************** Type Definitions *******************************/
/***************** Macros (Inline Functions) Definitions *********************/
/************************** Function Prototypes ****************************/
int TempSensorExample(u16 IicDeviceId, u8 TempSensorAddress,
						  u8 *TemperaturePtr);
int SetUpInterruptSystem(XScuGic *XScuGicInstancePtr);
int ScuGicInterrupt_Init(u16 DeviceId,XIic *IicInstancePtr);
static void  SendHandler (void *CallbackRef, int ByteCount);
static void RecvHandler(void *CallbackRef, int ByteCount);
static void StatusHandler(void *CallbackRef, int Status);
void My_XIic_InterruptHandler(void *InstancePtr);
/************************** Variable Definitions **************************/
XScuGic InterruptController; /* Instance of the Interrupt Controller */
static XScuGic_Config *GicConfig;/* The configuration parameters of thecontroller */
XIic Iic;		  /* The instance of the IIC device */
int TransmitComplete = 0;
 * The following structure contains fields that are used with the callbacks
 * (handlers) of the IIC driver. The driver asynchronously calls handlers
 * when abnormal events occur or when data has been sent or received. This
 * structure must be volatile to work when the code is optimized.
volatile struct {
	int  EventStatus;
	int  RemainingRecvBytes;
	int EventStatusUpdated;
	int RecvBytesUpdated;
} HandlerInfo;
* The purpose of this function is to illustrate how to use the IIC driver to
* read the temperature.
* @param	None
* @return	XST_SUCCESS if successful, XST_FAILURE if unsuccessful
* @note		None
int main(void)
	int Status;
	u8 TemperaturePtr;
	 * Call the TempSensorExample.
	Status =  TempSensorExample(IIC_DEVICE_ID, CAMERA_SLAVE_ADDRESS,
							&TemperaturePtr);
	if (Status != XST_SUCCESS) {
		xil_printf("IIC tempsensor Example Failed\r\n");
		return XST_FAILURE;
	xil_printf("Successfully ran IIC camera read Example\r\n");
	xil_printf("Value returned: 0x%x \r\n",TemperaturePtr);
	return XST_SUCCESS;
* The function reads the temperature of the IIC temperature sensor on the
* IIC bus. It initializes the IIC device driver and sets it up to communicate
* with the temperature sensor. This function does contain a loop that polls
* for completion of the IIC processing such that it may not return if
* interrupts or the hardware are not working.
* @param	IicDeviceId is the XPAR_<IIC_instance>_DEVICE_ID value from
*		xparameters.h for the IIC Device
* @param	TempSensorAddress is the address of the Temperature Sensor device
*		on the IIC bus
* @param	TemperaturePtr is the data byte read from the temperature sensor
* @return	XST_SUCCESS to indicate success, else XST_FAILURE to indicate
*		a Failure.
* @note		None.
int TempSensorExample(u16 IicDeviceId, u8 TempSensorAddress, u8 *RecBuffer)
	int Status;
	static int Initialized = FALSE;
	XIic_Config *ConfigPtr;	/* Pointer to configuration data */
	u8 buff[1];
//INIT------------------------------------------------------
	if (!Initialized) {
		Initialized = TRUE;
		 * Initialize the IIC driver so that it is ready to use.
		ConfigPtr = XIic_LookupConfig(IicDeviceId);
		if (ConfigPtr == NULL) {
			return XST_FAILURE;
		Status = XIic_CfgInitialize(&Iic, ConfigPtr,
						ConfigPtr->BaseAddress);
			return XST_FAILURE;
		 * Setup handler to process the asynchronous events which occur,
		 * the driver is only interrupt driven such that this must be
		 * done prior to starting the device.
		XIic_SetRecvHandler(&Iic, (void *)&HandlerInfo, RecvHandler);
		XIic_SetSendHandler(&Iic, (void *)&HandlerInfo, SendHandler);
		XIic_SetStatusHandler(&Iic, (void *)&HandlerInfo,
						StatusHandler);
		 * Connect the ISR to the interrupt and enable interrupts.
		Status =  ScuGicInterrupt_Init(XPAR_PS7_SCUGIC_0_DEVICE_ID,&Iic);
			return XST_FAILURE;
		 * Start the IIC driver such that it is ready to send and
		 * receive messages on the IIC interface, set the address
		 * to send to which is the temperature sensor address
		XIic_Start(&Iic);
		XIic_SetAddress(&Iic, XII_ADDR_TO_SEND_TYPE, TempSensorAddress);
//INIT---------------------------------------------------------------
	Status = XST_FAILURE;
	buff[0]=0x0A;
	if (XIic_MasterSend(&Iic, buff, 1) !=XST_SUCCESS){
		return Status;
	//while(TransmitComplete ==0);
	 * Attempt to receive a byte of data from the temperature sensor
	 * on the IIC interface, ignore the return value since this example is
	 * a single master system such that the IIC bus should not ever be busy
	if (XIic_MasterRecv(&Iic, RecBuffer, 1))
		return Status;
	 * The message is being received from the temperature sensor,
	 * wait for it to complete by polling the information that is
	 * updated asynchronously by interrupt processing
	while(1) {
		if(HandlerInfo.RecvBytesUpdated == TRUE) {
			 * The device information has been updated for receive
			 * processing,if all bytes received (1), indicate
			 * success
			if (HandlerInfo.RemainingRecvBytes == 0) {
				Status = XST_SUCCESS;
			break;
		 * Any event status which occurs indicates there was an error,
		 * so return unsuccessful, for this example there should be no
		 * status events since there is a single master on the bus
		if (HandlerInfo.EventStatusUpdated == TRUE) {
			break;
	return Status;
	* Connect the interrupt controller interrupt handler to the hardware
	* interrupt handling logic in the ARM processor.
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
	(Xil_ExceptionHandler) XScuGic_InterruptHandler,
	* Enable interrupts in the ARM
	Xil_ExceptionEnable();
	return XST_SUCCESS;
	int Status;
	* Initialize the interrupt controller driver so that it is ready to
	* use.
	GicConfig = XScuGic_LookupConfig(DeviceId);
	if (NULL == GicConfig) {
	return XST_FAILURE;
	Status = XScuGic_CfgInitialize(&InterruptController, GicConfig,GicConfig->CpuBaseAddress);
		return XST_FAILURE;
	* Setup the Interrupt System
	Status = SetUpInterruptSystem(&InterruptController);
	return XST_FAILURE;
	 * Perform a self-test to ensure that the hardware was built
	 * correctly
	Status = XScuGic_SelfTest(&InterruptController);
		return XST_FAILURE;
	* Connect a device driver handler that will be called when an
	* interrupt for the device occurs, the device driver handler performs
	* the specific interrupt processing for the device
	Status = XScuGic_Connect(&InterruptController,
			XPAR_FABRIC_IIC_0_VEC_ID,
			(Xil_ExceptionHandler)XIic_InterruptHandler,
			(void *)IicInstancePtr
	return XST_FAILURE;
	* Enable the interrupt for the device and then cause (simulate) an
	* interrupt so the handlers will be called
	XScuGic_Enable(&InterruptController, XPAR_FABRIC_AXI_IIC_0_IIC2INTC_IRPT_INTR);
	return XST_SUCCESS;
static void SendHandler(void *CallbackRef, int ByteCount)
	TransmitComplete = 1;
* This receive handler is called asynchronously from an interrupt context and
* and indicates that data in the specified buffer was received. The byte count
* should equal the byte count of the buffer if all the buffer was filled.
* @param	CallBackRef is a pointer to the IIC device driver instance which
*		the handler is being called for.
* @param	ByteCount indicates the number of bytes remaining to be received of
*		the requested byte count. A value of zero indicates all requested
*		bytes were received.
* @return	None.
* @notes	None.
	HandlerInfo.RemainingRecvBytes = ByteCount;
	HandlerInfo.RecvBytesUpdated = TRUE;
* This status handler is called asynchronously from an interrupt context and
* indicates that the conditions of the IIC bus changed. This  handler should
* not be called for the application unless an error occurs.
* @param	CallBackRef is a pointer to the IIC device driver instance which the
*		handler is being called for.
* @param	Status contains the status of the IIC bus which changed.
* @return	None.
* @notes	None.
	HandlerInfo.EventStatus |= Status;
	HandlerInfo.EventStatusUpdated = TRUE;
void My_XIic_InterruptHandler(void *InstancePtr){
	XIic_InterruptHandler(InstancePtr);
Observer aviteri@dorc
Re: bare metal axi iic interrupt help
HI heitbrsp,
I am having the same problem state here.
What I noticed is : if you uncomment the
then it works. I have in my code the following
while (!TransmitComplete || (XIic_IsIicBusy(InstancePtr) == TRUE)); /* Wait till the transmission is completed. */
 With that the interrupt is triggered and the SendHandler function is reached.
However, I don't like it because the processor is kept in the while waiting.
Did you solve your issue ?.
I am looking for a solution in which the while is not used.
Greetings,
AV.
