Teacher muzaffer
custom axi ip with microblaze
I am following this AR to make a microblaze design with a custom axi IP: http://www.xilinx.com/support/answers/56609.html
What's somewhat confusing is how to use the generated wrapper. Is it a good idea to ask for a "copy generated wrapper to allow user edits" ? or is it better to "let vivado manage wrapper ..." and add another top level which instantiates the wrapper and the custom ip while propagating the board level signals.
Any comments on this flow would be appreciated.
Re: custom axi ip with microblaze
The option let vivado manage wrapper will automatically update the HDL as it is being generated.
Whereas other option "copy generated wrapper to allow user edits" will just copyt the file and will not update during HDL
I usually use let vivado manage wrapper
--Hem
--Hem
Teacher muzaffer
I ended up making the extra axi ports external and instantiated the wrapper at a new top level which uses some of the ports and forwards the rest to top.
