Observer maria@tbg
data format (ILA)
Hi all
We are still puzzling out a "simple" DMA project.
(which I posted already earlier https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/PS-PL-communication-code-review/td-p/766398
and https://forums.xilinx.com/t5/BRAM-FIFO/polled-simple-DMA-example-with-VHDL-interface/td-p/764830/page/2 )
Now I did a comparison on debugging my running VHDL code and the running VHDL code of the example project using ILA. (https://www.xilinx.com/support/answers/57561.html)
The individual signal lines are the same but the data format is weird.
1) Could anyone please explain me how to read the data? It is expected to be (decimal) 12 to 43 but the maximum value is 724183336 for example. When read in PS, the actual data is 43. Changing the radix doesn't help. [screenshot attached]
2) The .c code in PS writes u8 data into an u8 ptr but DMA expects u32 (as far as I understood it).
I don't quite get how this is done? (I don't understand that but is line "Value = (Value + 1) & 0xFF" type casting it somehow? [original .c file attached]
Your help is very much appreciated.
Thanks, Maria
Observer maria@tbg
Re: data format (ILA)
Solved it.
It's four u8 numbers combined into one u32.
s_axis_tdata <= std_logic_vector(index_counter_u8+3) & std_logic_vector(index_counter_u8+2) & std_logic_vector(index_counter_u8+1) & std_logic_vector(index_counter_u8) ;
Teacher muzaffer
maria@tbg you need to zoom on to a valid tvalid/tready transaction to see exactly what data is begin transferred which is difficult to see from the post you made. The transaction happens on the edge of the clock which see the tready & tvalid high for one full cycle. Zoom into that condition and review it and if it still doesn't make sense post here that portion of the waveform.
Observer maria@tbg
muzaffer
I did zoom in and now I also attach the screenshot.
As I said, the last value is this weird 724183336 which is supposed to be 43.
I've attached a zoom of hex radix and unsigned decimal radix.
I have absolutely no clue which data format that is, I thought it is unsigned decimal.
Thanks, Maria
Observer maria@tbg
Solved it.
