Participant lizhang86
gem external fifo tx_r_rd stuck low
I want to access gem through external FIFO.  The tx_r_rd would go high after tx_r_data_rdy is set, but it would be stuck low after 8 clock cycles.  There is no status signal to indicate an error.  More detail is in the attached ila capture.  I cannot find any relevant debug information regarding this issue in ug1805.  Any help would be appreciated.
Li
Re: gem external fifo tx_r_rd stuck low
I solved my problem by enabling the external_fifo_interface register in GEM (0xff0e004c for gem3) using mwr. Apparently, it is not enough to just select external fifo interface for gem in the block design.  The external_fifo_interface register must also be enabled during software configuration.  These procedures to enable external fifo mode for gem are not documented in TRM.
Best Regards,
Li
Best Regards,
Li
