how to read .txt file in Zynq arm procedure?
i have work continue on read .txt file from host pc to Sdk through Zynq.
my question is its possible if i convert .txt file into hex or else and then read file.because in Zynq processor support arm processor. give any suggestion i am very close of this task please help.
thanks
mohit
Teacher drjohnsmith
Re: how to read .txt file in Zynq arm procedure?
I cant help, but you might want to give a bit more background on what you have done, what tools your using etc. for instance, have you tried the hello world program
Thank you sir for giving response,
1. Sir I have Successful  done hello world Program flash memory In SDK.
2.Then I have moved on read file.
3.Here problem is Zynq processor cannot understand .txt file which is on host PC and using fopen command.
4. I have put .txt file every where such as on desktop, in SDK etc. It can't pick up a data from. Txt file.
Please help
Mohit
