how to send data from ps to pl with 250 msps?
hello everyone,
 I am trying to send data from ps to pl to run the DAC which runs at 250 MSPS. I tried axi gpio but it is giving output at very slow speed.
which method should I try for sending data from ps to pl with 250 MSPS, please give me any reference application note example.
thanks in advance
Amit
Re: how to send data from ps to pl with 250 msps?
Hi @amitlwaghmare,
The Below are the PS-PL interfaces.
As per my understanding you need a Master in PS which sends the data to the PL at 250 MSPS. If I understood correct then you can you the AXI GP master port to transfer the data from PS to PL.
the AXI Master GP port transfers the data at 600MB/s
Here is one Xapp https://www.xilinx.com/support/documentation/application_notes/xapp1183-zynq-xadc-axi.pdf
this xapp is not what you are looking for, but it explains a way to use the GP port.
Best Regards,
Srikanth
@savula thanks for your reply,
 In my application, I want to send data to the DAC with 250 MSPS.  Data for the DAC is continuously changing.
form PL, I successfully ran the Dac. but now I want to send the data form ps to the DAC. how to do this?
I tried transfer-data-from-ps-to-pl-through-the-dma-simple-dma-with-custom-ip/ this type of design for data transfer . but I didn't understand how to send data continuously through DMA.
Hi @amitlwaghmare,
I think you are in right direction. from the tutorial what I understood is sending data from the PS to DMA and then the custom IP reading the data from the DMA and sending it to LED port. if you see the SDK application  streamEXampleSimpleDMA.c mentioned in the tutorial, increase the max_pkt_len to any required number (how many number of bytes you want to send in single transfer)
after that load your DAC samples in the buffer as shown below:load_val.PNG
Change the custom IP with your own IP which will read the data from the DMA and sends the data to DAC.
now in SDK write the data continuously to the DMA the that data will be read from DMA and sent to DAC using the Custom IP.
Best Regards,
Srikanth
@savula thanks for the reply,
I had done this tutorial for my data transfer but now I want to see the data on ILA, to understand at which rate data is coming from the PS. how can I see this?
what is the relation between the fclk_clk0 and the rate at which data is coming out from my custom IP?
Amit
Participant fincs
Data from PS is on the bus MM2S, inteface Axi-Stream
