Observer thobmei
ipif enable/enable lock
Hi im trying to add an enable bit to my ipif logic. Once the Enable occurs enable_temp should be hold until EOF becomes '1'.
I tried to implement is this way:
enable <= slv_reg0(0);
-- Locks the Enable
enlock: process(Bus2IP_Clk, Bus2IP_Reset)
begin
      if Bus2IP_Reset = '1' then
         enable_temp <= '0';
      elsif Bus2IP_Clk='1' and Bus2IP_Clk'event then
         if (enable='1') or EOF='1' then
            enable_temp <= enable;
         end if;
      end if;
end process enlock ;
But It seems to be optimiced to NULL
can you tell whats going wrong?
Observer thobmei
Re: ipif enable/enable lock
I solved it on my own I had some Probmes with Little and Big endian ...
Instead of
use
if (enable='1') and EOF='1' then
If you use the OR condition, enable_temp <= enable; will run whenever enable is 1 OR EOF is 1, not when enable AND EOF are both 1.
Best,
JM
Observer thobmei
