Voyager
Voyager
link microblaze, bit and elf file
using Vivado 2017.2 whats the best way to link the bit and elf file.
currently if I program the bit then run elf from SDK it work. but using updateMem command couldn't get my DMA working.  I suspect it has to do with memory association etc.
do I need generate a memory configuration file or MMI or others? any guide.  I am using a MIG so I don't know if that's the issue
when running updatemem I got these error, seem due to my MIG which is at address 0x8000000
Command: update_mem -meminfo test.mmi -data test.elf -proc design_1_inst/mb_ss/microblaze_0 -bit test.bit -out test_out.bit
CRITICAL WARNING: [Updatemem 57-172] The elf file code segment 1 with a defined address range of [0x80000000:0x8004D5A3] does not match any existing address spaces as defined in the mmi file. Check the elf file and the mmi file for consistency.
0 Infos, 0 Warnings, 1 Critical Warnings and 1 Errors encountered.
update_mem failed
update_mem: Time (s): cpu = 00:00:05 ; elapsed = 00:00:05 . Memory (MB): peak = 193.996 ; gain = 142.863
ERROR: [Common 17-39] 'update_mem' failed due to earlier errors.
INFO: [Common 17-206] Exiting updatemem at Mon Feb 26 14:19:57 2018...
ERROR: [Updatemem 57-153] Failed to update the BRAM INIT strings for amc598_tool.elf and test.mmi.
Re: link microblaze, bit and elf file
Hi @s002wjhw,
You need to have your code in local BRAM. You cannot initialize the DDR memory with the bitstream.
Change the memory in the linker settings
Hope that helps,
Florent
Hi @s002wjhw,
Hope that helps,
Florent
Voyager
Voyager
I did change the linker file, but now i'm getting axi dma interrupt handler error.  The design is similar to Xapp1026 where axi Ethernet connect to dma, connect to DDR.
Hi @s002wjhw,
As the initial issue is solved, you should close this topic by marking it as solved and create a new topic for the axi dma interrupt handler error giving details about what you get. Some other members of the community might have faces the same issue.
Florent
