Observer samuelcotard
lwIP echo server generates trap error
I faced an issue in the lwIP echo server (2015.4) example that takes me a lot of time.
tcp_outpout() accesses and modifies the pbuf global variable used by the whole lwIP stack. But tcp_output() is called both from the application and from interrupt routine tcp_tmr()->tcp_fasttmr().
In the lwIP stack there is no protection against interrupts when accessing the pbuf thus it is forbidden to call tcp_output() in an interrupt as it corrupts the pbuf global variable.
The solution is to call tcp_tmr() in the main() loop  according to a flag/variable indicating the timer's overflow. This flag can be set in the interrupt routine.
The issue occurs very often in high throughput applications but can occur randomly in any application.
I hope it can help other users to improve their application's reliability and Xilinx to improve the example code.
Samuel
Re: lwIP echo server generates trap error
The solution is to call tcp_tmr() in the main() loop and not in the interrupt routine.
What is amazing is that it seems to be a known issue for Xilinx. Why old code is implemented in new releases?
https://forums.xilinx.com/t5/Embedded-Development-Tools/lwip-crashing-after-several-days-of-runtime/m-p/399183/highlight/true#M29700
