lwip igmp ( am i doing right? )
hallo world,
I try to use igmp but I'm not sure if I'm doing right. ( Since i dont have a real igmp-Sever to connect to...)
I use VLC to stream out data to lets say 224.0.0.0.
To receive data with Lwip i do this:
1st: igmp_joingroup( 224.0.0.0)
2nd: Build UDP-Connection with [ source: unknown; destination: 224.0.0.0 ]
But is this right? Would a real igmp behave like this?
I have a fixed ip for the receiving module ( 196.168.1.1)
So actual question:
After join-group ( 224.0.0.0). Are the packets send to 224.0.0.0 or to 196.168.1.1 ?
Is it clear what I'm trying to get to know?
Voyager
Voyager
Re: lwip igmp ( am i doing right? )
You can use basic example design of EMAC with address swap module generated from coregen which will send and receive IGMP ping packet  request using arp -s command.
