Voyager
Voyager
microblaze bootloader
for qspi i'm assuming I need  SREC SPI bootloader? not SREC bootloader
do I need modify blconfig.h?  or I can just generate .mcs for my elf with correct flash address offset?
I guess whats the correct way to put my elf in part of flash for my microblaze to run it upong pwr up.   I have a design that require DDR, basically xapp1026 TCP/ip LWip, that need to auto run upon power up.  I think the only way to do that is have a bootloader?
Re: microblaze bootloader
Yes you are correct. You should use SPI SREC bootloader for this and edit blconfig.h file.
Please follow the instructions from https://www.xilinx.com/support/answers/63605.html
