Voyager
Voyager
running microblaze from external ddr
is there anyway to run microblaze from external ddr, upon pwr up?
right now I have a bit and elf.  but my elf require axi dma access to ddr, if I run from LBM, I get axidma error interrupt is asserted.  but if I set the linker script to DDR, and run manually from sdk it work.
Re: running microblaze from external ddr
Steps are shown here.
https://www.xilinx.com/support/answers/63605.html
This is an old AR, but the steps are still relevant
This works from SDK as this using the debugger to download the elf to the DDR. If you want to do this this without the debugger, then you would need a bootloader from flash to load the elf into ddr and then handoff to execute from DDR.
Their is a SREC templates in the SDK that you can use
Voyager
Voyager
is there a guide on how this work?
i'm assuming I put mmi/bootloader.elf + .bit into download.bit generated by SDK
then using vivado generating MCS file base on this download.bit + my app elf set at certain address offset. so its 0x0 download.bit + size of bit for address offset-> .elf ?
