Voyager
Voyager
standalone microblaze compiler/make error?
I'm currently has this error for standalone compile
 make: *** No rule to make target `test.o', needed by `raw_t.elf'.  Stop.
All I did is add new source *.c file, now even after I remove that file i'm getting below error it seem like some kind makefile error, since all the code compile fine
i'm also getting other errors see screenshot(the error display real fast then the screen was refreshed, I was able to get a screen shot when it displayed.
Teacher xilinxacct
Re: standalone microblaze compiler/make error?
@s002wjhw
if there were no files with .o, rm will issue a complaint, however, You should be able to silence that with rm -f *.o
Hope that helps
If so, please mark as solution accepted... Kudos also welcomed :-)
