Observer creator
why My computer can't pinging the zedboard???
I create the block diagram .I created the lwip echo server in sdk.I load it to zedboard.When I load the blue led light blinked.But when I ping from my computer(command prompt) It shows destination host unreachable...
Teacher xilinxacct
Re: why My computer can't pinging the zedboard???
@creator
Are you pinging with the hostname or the IP address? Try the IP address, and see it that makes a difference. (e.g. if the machine you are coming from doesn't resolve the name, the IP address should still work, assuming you are on the same subnet)
Hope that helps
If so, please mark as solution accepted to close the issue. Kudos also welcomed. :-)
