Observer saurabhnair
zc702 ethernet example
Xilinx provides the example for ethernet named "xemacps_example_intr_dma.c"
I tried to run this program using the "Run on Hardware" option in SDK. The only change I made was change the MAC address it sets to the MAC address of my laptop. I connected the board with laptop using crossover cable. Yet when I tried to debug, I found that the code hangs at, "waiting for the transmission to complete". Am I doing something wrong, or is anything more needed to be done.
Awaiting your suggestions
Saurabh
Tags (2)
Re: zc702 ethernet example
On debugging the example code, I found that after executing the function "XEmacPs_Transmit", the code enters the "Xil_ExceptionNullHandler". I had checked the code, and found that the handlers have been set for send, receive and error. Any ideas as to why the code is enterng the NullHandler, instead of SendHandler?
Awaiting any suggestions.
Saurabh
