Change the -optimization_level' configuration:
Here is the output of the vivado_hls.log
I wonder how to change the default efforts to the highest effort?
What should I add in the makefile?
INFO: [SYN 201-201] Setting up clock 'default' with a period of 3.33333ns.
INFO: [HLS 200-435] Setting 'config_sdx -optimization_level' configuration: config_rtl -vivado_phys_opt=none
INFO: [HLS 200-435] Setting 'config_sdx -optimization_level' configuration: config_bind -effort=medium
INFO: [HLS 200-435] Setting 'config_sdx -optimization_level' configuration: config_schedule -effort=medium
Please try -O option, like -O3
Type xocc --help to get help info:
    -O [ --optimize ] arg        Optimize level: [0-3,s,quick]; default is 0
brucey
