SDACCEL keeps reporting "Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running"
I am running sdaccel targeting hardware run.
The software emulation and hardware emulation goes well.
In the compilation for the hw, the sdaccel keeps reporting "Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running."
This has last for more than 10 hours.
[14:03:57] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:05:00] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:06:04] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:07:07] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:08:11] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:09:14] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:10:18] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:11:22] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:12:25] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:13:29] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:14:32] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:15:36] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:16:39] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:17:43] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:18:46] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:19:50] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:20:53] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:21:57] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:23:01] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:24:05] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:25:08] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:26:12] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:27:15] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:28:19] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:29:22] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:30:26] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:31:29] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:32:33] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:33:36] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:34:40] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:35:43] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:36:46] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:37:50] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:38:53] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:39:57] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
[14:41:00] Block-level synthesis in progress, 63 of 64 jobs complete, 1 job running.
I suspect the issue may caused by the overusing of the resource.
Resource utilizaiton of the kernle got from the estimate report is here:
Area Information
Compute Unit  Kernel Name  Module Name               FF      LUT     DSP  BRAM
pcaf_fpga_1   pcaf_fpga    read_query_pca            5104    10905   0    1
pcaf_fpga_1   pcaf_fpga    read_query_or             3573    9197    0    0
pcaf_fpga_1   pcaf_fpga    d_copy_g2oc_queries       8683    20330   0    1
pcaf_fpga_1   pcaf_fpga    query_cop_g2oc            8721    20477   0    1
pcaf_fpga_1   pcaf_fpga    filtering_entry18         3       64      0    0
pcaf_fpga_1   pcaf_fpga    filtering_entry1330       2       64      0    0
pcaf_fpga_1   pcaf_fpga    filtering_Block_proc      150     152     0    0
pcaf_fpga_1   pcaf_fpga    read_feature_pca          5984    10926   0    0
pcaf_fpga_1   pcaf_fpga    d_copy_g2oc_pca_features  6078    11149   0    0
pcaf_fpga_1   pcaf_fpga    filtering_Block_proc1327  162     161     0    0
pcaf_fpga_1   pcaf_fpga    dist_calc_PCA             945     578     16   0
pcaf_fpga_1   pcaf_fpga    read_feature_or           263594  524378  0    0
pcaf_fpga_1   pcaf_fpga    dist_calc_or1             55205   24525   960  0
pcaf_fpga_1   pcaf_fpga    dist_calc_or2             2880    16506   0    0
pcaf_fpga_1   pcaf_fpga    dist_calc_or3             176     1069    0    0
pcaf_fpga_1   pcaf_fpga    dist_calc_or              59227   42145   960  0
pcaf_fpga_1   pcaf_fpga    k_max                     113     312     0    0
pcaf_fpga_1   pcaf_fpga    dist_calc_pcaf            338767  578816  976  6
pcaf_fpga_1   pcaf_fpga    filter_sum                37      78      0    0
pcaf_fpga_1   pcaf_fpga    filtering                 345992  592810  976  24
pcaf_fpga_1   pcaf_fpga    d_copy_oc2g               1316    1609    0    0
pcaf_fpga_1   pcaf_fpga    pcaf_fpga                 359432  618648  976  34
This is the resource for the FPGA I am using, i.e., VCU1525 board.323232.JPG
From the report, I can see the LUT account for the biggest proportion around 50%.
This is for the whole chip. But the static area on the DSA still consume some FPGA logic.
1. I want to know what is the logic resource VCU1525 provided for the user excluding the static area.
2. What's the other possible resaons for this problem?
Hi, @mathmaxsean ,
Please try to find the Vivado synthesis report and check the detailed synthesis error message.
@hongh
Thanks very much!
I tried to search this report under the _x folder.
But there are lots of synthesis reports, could you let me know how can I find the right one?
Hi, @mathmaxsean ,
It seems that the issue is not casued by utilization, it's an OOC synthesis issue for a submodule.
The platform(VU1525) utilization is attached.
Can you open the Vivado project in SDx? (Xilinx -> Vivado Integration -> Open Vivado project).
 If the project has been created, we can see which module fails in synthsis.
