SDAccel security examples on AWS EC2 F1 instances
Hi all,
I am trying to run the various security examples from:
https://github.com/Xilinx/SDAccel_Examples/tree/70a0f3edc6d78f3de13806ec7a7a01d1fbe0d2bd/security
The RSA one failed with an error of "openssl/bn.h' file not found" when trying to run the emulation on software, AES would not emulate on software but SHA1 would, AES and SHA1 failed when trying to build on hardware. Does anyone have any tips on getting these to run on the AWS EC2 F1 instances? I know they're not specifically built to run on F1 instances but it has a link at the bottom of each algorithm on how to run in cloud environments so I assume they should be able to be run.
Thanks!
Hi, @canadyre_ ,
The issue has been reflected to the developer.
When we have update, we will let you know.
Hi @canadyre_,
All the security examples had been removed from public github couple of days back.
if you check the latest link:
Some of the security examples(RSA) are working fine in command line flow, but few other are not working fine and even the performance is not as expected.
So, we removed the security examples from public github. Once, we update the examples locally and achieve the expected performance will push to public github.
Hi @canadyre_,
Can you try the following steps and check if the issue still remains:
1. sudo rm -rf /opt/Xilinx/SDx/*rte*
2. cd aws-fpga
3. source sdaccel_setup.sh
4. sudo sh
5. fpga-clear-local-image -S 0
6. source /opt/Xilinx/SDx/2017.4_rte.dyn/setup.sh
7. <run your application>
Hi bchebrol,
There is not an rte file in the /opt/Xilinx/SDx folder, instead there is 2018.2.op2258646.
Robert Canady
Hi @canadyre_,
just do git clone and continue from 2nd step:
if f1_dynamic:
git clone http://github.com/aws/aws-fpga.git -b RC_v1_3_9
elsif f1-04261818_dynamic
git clone http://github.com/aws/aws-fpga.git -b master
Hi @canadyre_,
if you are using 2018.2, then the corresponding source file path :
  • source /opt/xilinx/xrt/setup.sh
