how to use both multiple ddr bank and multiple compute unit in SDAccel?
there are examples about using multi ddr bank and multi compute unit separately in SDAccel. but how to use both. for example, in a project, i have two compute units, and compute unit 1 connect to ddr bank0, compute unit 2 connect to ddr bank1. does the SDAccel support?
回复: how to use both multiple ddr bank and multiple compute unit in SDAccel?
Yes, you can specify kernel instance name in --sp option of xocc.
--sp <COMPUTE_UNIT>.<MEM_INTERFACE>:<MEMORY>
Refer to specific version of SDAccel User Guide for syntax example.
Hi @suming,
You can check xilinx LZ4 Compression for reference.
https://github.com/Xilinx/Applications/blob/master/data_compression/xil_lz4/Makefile
Hi @bchebrol
Thanks for your reply. this is the example i want to find.
But i have other question.
Every CU is identified in xil_lz4/src/xil_lz4.cpp.
for (int i = 0; i < C_COMPUTE_UNIT; i++)
compress_kernel_lz4[i] = new cl::Kernel(*m_program, compress_kernel_names[i].c_str());
And compress_kernel_names is defined in xil_lz4/src/xil_lz4.h.
std::vector<std::string> compress_kernel_names = {"xil_lz4_cu1",
"xil_lz4_cu2",
"xil_lz4_cu3",
"xil_lz4_cu4",
"xil_lz4_cu5",
"xil_lz4_cu6",
"xil_lz4_cu7",
"xil_lz4_cu8",
when i use this method, there is error that can not find the xxx_cu1. why it got this error? i already set the CU number to 2. does there need other settings?
Hi @bchebrol
"xil_lz4_cu2",
"xil_lz4_cu3",
"xil_lz4_cu4",
"xil_lz4_cu5",
"xil_lz4_cu6",
"xil_lz4_cu7",
"xil_lz4_cu8",
Hi @suming
This error is observed when you made changes to your source or the xil_lz4 link provided by @bchebrol  ?
By default we have set 2 CUs for computation.
Kali
Hi @suming ,
Currently tere are some known issues of supporting multiple Compute units which are connected to different DDRs (non identical case).
Below LZ4 example is not a multiple compute units example:
Above example is providing a workaround to handle the case. It has different kernel names which has exact identical functionality but different ddr connection.
So in host code, individual kernel has to be called in host code with thier respective name.
-Heera
